web-features
2.36.1 • Public • Published
Curated list of Web platform features
web-features is the package that describes Web platform features and provides Baseline status reports.
Subscribe to the Upcoming changes announcements thread for news about upcoming releases, such as breaking changes or major features.
Usage
npm install web-features
import { browsers, features, groups, snapshots } from "web-features";
Or, without Node.js:
import data from "web-features/data.json" with { type: "json" };
const { browsers, features, groups, snapshots } = data;
To import the JSON schema with or without Node.js:
import schema from "web-features/data.schema.json" with { type: "json" };
Rendering Baseline statuses with web-features
If you're using web-features to render Baseline iconography or browser logos with support markers, then you must follow the name and logo usage guidelines.
For Baseline iconography, follow this procedure for each feature:
  1. If status.baseline is "high", then show an affirmative "widely available" icon.
  2. If status.baseline is "low", then show an affirmative "newly available" icon.
  3. If status.baseline is false, then show a "limited availability" non-Baseline icon.
    Note: All features that have the discouraged property are, by definition, non-Baseline, and status.baseline will be false. If a feature has the discouraged property, consider showing a message describing the feature's discouraged status instead of Baseline iconography. Showing Baseline iconography for discouraged features may confuse readers.
  4. If status.baseline is undefined, then do not show any Baseline or non-Baseline badge.
For browser support iconography (that is, browser logos and checkmarks and Xs), follow this procedure for each browser:
  1. If status.baseline is "high" or "low", then show a green checkmark (✅, "supported") beside each browser's logo icon.
  2. If status.baseline is false and the browser's status.support key (for example, status.support.edge) is undefined or false, then show a gray X ("unsupported") beside the browser's logo icon.
  3. If status.baseline is "high" or "low" and the browser's status.support key is a string, then show a green checkmark ("supported") beside the browser's logo icon.
If you wish to report browser version numbers, avoid showing version numbers alone. Developers and users often do not know whether a version number refers to a very recent or old release. If you must show a version number, consider contextualizing that number by showing a release date, a relative date (such as "Released … years ago"), an offset (such as "… releases ago"), or usage statistics relevant to your audience (such as "…% of your visitors in the last 90 days").
Readme
Keywords
none
Package Sidebar
Install
npm i web-features
Weekly Downloads
13,894
Version
2.36.1
Apache-2.0
Unpacked Size
1.33 MB
Total Files
7
Last publish
Collaborators
  • patrickbrosset
  • tidoust
  • google-wombot
  • foolip
  • ddbeck
